I am running into an issue where when I run a 50/50 split redirect test using VWO Amplitude is firing two pageview tags - one for the control and the other for the variant essentially double-counting pageviews.
How can I best setup our VWO integration to avoid this behavior? Or, is there a way to filter out the double counting on the backend.
Be the first to reply!
