Data retention
See the latest Starter plan updates here
  • Starter plans have access to query up to 1 year of data (could be last 365 days or between n date - n+1year date with only 365 days at max)
  • Plus plans have access to query up to 2 years of data (could be last 24 months or between n month - n+24month)
  • Scholarship/Growth/Enterprise have access to query unlimited years of data
How long does Amplitude retain (and make accessible)our user/event data?
Best answer by Saish Redkar
Hey @bhill ,
Afaik, Amplitude supports unlimited data retention right from their Free Plan onwards.
However, there are charting limits on how far you can go wrt time when visualizing your data in charts like Event Segmentation depending on your granularity.
eg. you can only visualize your daily metrics for the past 365 days. To increase the timeframe you would have to switch to weekly, which hits the max at last 52 weeks.
Scholarship/Growth/Enterprise plans have access to query unlimited years of historical data. For example, they can query data from 2015 - 2018, or from 2020 - 2023. Note: There is a 3 year limit imposed on chart queries, with the following date interval limits
  • 365 days
  • 52 weeks
  • 36 months
  • 12 quarters
If you are planning on having access and owning your raw data outside Amplitude, then here are a few options
  • If you are a paid customer, then you can setup recurring exports to the cloud destination of your choice ( Amazon S3, Snowflake, Google Cloud Storage, ) directly from the Amplitude UI.
  • If you are not on a paid plan, then you can also leverage the Export API and create your own custom ETL pipeline.
Saish Redkar
Expert
Forum|alt.badge.img+10
  • Expert
  • 1381 replies
  • Answer
  • August 6, 2021
Hey @bhill ,
  • 365 days
  • 52 weeks
  • 36 months
  • 12 quarters
tracy.guo
Team Member
Forum|alt.badge.img+3
  • Amplitude Support
  • 39 replies
  • August 6, 2021
Hi @bhill !
@Saish Redkar ‘s answer is on point. We provide unlimited data retention for all plan types.
A few additional notes:
  • More details on how much data can be visualized for each date interval option can be found here: https://help.amplitude.com/hc/en-us/articles/115002923888#h_bee3799c-cd45-44f2-adde-b7c06bc5a8b4
  • As Saish said, the maximum amount of data you could potentially visualize at a time is 12 quarters of data (aka 3 years), but this doesn’t necessarily mean that it must be the most recent 3 years of data. You can use offsets or “Between” to look at more specific period of data prior to the last 3 years if needed.
Let us know if you have any questions!
Forum|alt.badge.img
  • New Member
  • September 1, 2021
A follow up question. Is it possible to change the setting for how long Amplitude stores the data and delete data older than e.g 6 months?
Kind regards
/J
Saish Redkar
Expert
  • Expert
  • 1381 replies
  • September 1, 2021
Hey @nordjac,
I don’t think this is currently possible within Amplitude UI as a self serve setting. But this could be something Amplitude Support can do on their backend for a customer if you reach out to them.
tracy.guo
Team Member
  • Amplitude Support
  • 39 replies
  • September 2, 2021
Hi @nordjac ! This is not an option/configuration that we can turn on or off, but if you have a success manager that you work with from Amplitude, they might be able to find other options.
