I have a problem using cyryllic values for event properties. Have somebody had something similar to this? Here is an example of what I see in amplitude dashboard:
testProperty: ÐиÑилиÑÑ
Hi @pavlo ,
Thanks for writing into the Community! I am very excited to see it being so active!!
I have just tested an event there by sending it in with the HTTP API V2 and I was able to ingest Cyrillic characters just fine, as you can see from the event named "My Test event". I have tested the same for the event properties and it also works just fine. How are you sending in the Cyrillic characters? Are you using the HTTP API or one of the SDKs? If so, which one? I can then look into this on my end. Thank you!
