Hey everybody!
Someone can tell me if it is possible to see bounce rate web event or scroll web event in Amplitude?
Thanks in advance!
Hi Marta Catalá
Are you looking ways to measure bounce rate in Amplitude or more like an auto trigger event support for bounce rate/ scroll down on a specific web page?
Here are some posts which might help you -
Thank you, Saish! Your resources have been very helpful for me. I have built a dashboard similar to the it appears in the solution of the second case you shared.
Here it is: https://analytics.amplitude.com/erudit/chart/y0u74qw?source=redirect%3A%20chart%20saved
I have a question related the dashboard that they share on the case. Why I do not have the event “start session” available in my environment? Here you can see they use start sessions instead of page view to check the bounce rate https://analytics.amplitude.com/demo/chart/new/iecpr2t
The Start Session events are something which need to enabled only via the iOS/Android SDK as highlighted in this doc.
Thank you, Saish! I have share those resources with my dev team. I really appreciare your work on here!
