Amplitude stopped receiving events
  • December 22, 2022
  • 810 views
Hi!
I try to solve a problem. The amplitude does not receive events. The problem concerns android and ios app version. The problem occurs when passing frontend application events. There are a couple of backend events that the amplitude accepts. Events are not blocked, not filtered, not hidden. Connection software has not changed and not update. All others analytics systems(not amplitude) receive and display events correctly. Last 3-4 days "Total Event Volume" graphic is in "flat". Application is available to user
Best answer by Denis Holmes
Hi @Ilya_Stashenka ,
This sounds like an implementation issue as I do not see any other reports of problematic ingestion. Can you link me a chart for your project? Can you also let me know which SDKs you are on for iOS and Android? And what is your ORG ID? What events were you expecting to receive and didn’t? I can then look into this for you.
Denis Holmes
Team Member
Forum|alt.badge.img+8
  • Team Member
  • 448 replies
  • Answer
  • December 23, 2022
Thanks for your feedback!
Feedback in private messages
