Hello, I just started at a company that uses SnowPlow for sending events to different tools.
I took a look at the snowplow doc and our implementation, and it looks like we're using 'custom structured events' which have a category, a label, and only one property field (which we fill with a json in order to pass several properties)
SnwoPlow’s doc about this is here: https://docs.snowplow.io/docs/understanding-your-pipeline/canonical-event/
Question: did anyone successfully integrate Snowplow and Amplitude? If so, how? I did some research and looks like it’s feasible via Google Tag Manager but that sounds like a clunky hack.
From the looks of it, I would be better off going the Amplitude SDK route, but the upside of connecting with Snowplow is the ability for snowplow to send historical data.
Thanks in advance!
Best answer by Esther Trapadoux
