@Yuanyuan Zhang hi thanks it helps!
Now a question follows up:
How do I create a segment for groups (or a cohort) who performed the custom event over 10 times on 3 separate days within the past 7 days?
The use case is to measure a weekly engagement metrics, which requires a certain level of frequency of using our product
Furthermore, let’s say a weekly active corp is identified, and I want to further track a monthly active corp growth trend, which is defined as “in the past 4 weeks, it was identified as weekly active at least 2 times.” How do I measure it?
Glad to hear that it helps! You are very welcome.
The closest we can get to your follow up question would be using the 'count in interval' feature, but the limitation is that you would need to set a longer time range for the intervals, instead of 8 days. By default, a week is MON-SUN and a month is a calender month. You can change the definition of week and quarter under protect settings though. “count in interval” cohorts are powered by the same backend logic as stickiness charts, which ignores the most recent incomplete interval and starts from the date you set.
Screenshot of example:
Yuanyuan
