I've been seeing this for a few days, on the dashboard chart metrics (conversion rates) won't load:
Is there something I need to adjust to fix this?
FYI - when I click into the chart I can see the conversion rate all right, just not on the dashboard.
Hey @artcities
You should be able to toggle the conversion rate view via KPI → Conversion Rate.
If not, then this could be a potential dashboard UI bug.
Let me know if I have understood your use case correctly. Hope this helps!
Hey @artcities
Yep tried that it still doesn't work.
Looks like a bug?
It's been there for more than a week now.
Hi @artcities
This is Yuanyuan from the Amplitude Support team - thank you for bringing this to our attention. We are in contact with the engineering team for investigation. I will let you know once I have update. Apologies for the inconvenience.
Kind regards,
Hi @artcities
Our Engineering team has resolved the issue. Sorry for the inconvenience and please let us know if you run into it again!
