Hey all,
We need to transfer our project, environments and data between Amplitude accounts without any app updates. Is it possible? Can some one share how to do it.
Hey valitovtm
You might have to reach out to support to get this done.
Jeremie Gluckman Denis HolmesYuanyuan Zhang
Thank you for looping in the team Saish Redkar. They’ll take a look. 😃
Hi valitovtm ! Welcome to the Amplitude Community and happy to help 👋
To clarify, do you need to move all of your data from one Amplitude organization to another? If so, can you share more information on why you are doing so - i.e. is the 2nd organization part of a paid plan and you have a Starter org with data that you need in the 2nd org?
Hi valitovtm We’re circling back to make sure you have everything you need. Were you able to make progress here?
