Is there a way to see what was received here that popped the error?
even the code, anything would help
Thanks in advance.
Hi Omriko ,
This is to show you the amount of times the type ingested was not an integer, I understand you want to see further into what values caused these errors? Can you send me a link to your data so I can have a look and see? Thank you!
Kind Regards,Denis
Thanks Denis!
It appears we did change the type in a data branch but haven’t fully approved it
this solved it.
Auto Capture is a very prominent feature for the Browser SDK and the Native SDK's i.e. the IOS and the Android SDKs. It allows us to capture the basic [Amplitude] events like Button clicks, Navigation to pages, Pages Viewed, etc. The project that I am currently working on already has a web version on which we use the…
Hello, Is there a way to make a query like: “Give me all the users that have the user property X equal to 10”, by using just any of the APIs, without making a cohort first through the Amplitude’s UI? Thank you!
