I can not see UTM parameters and this it the Tracking Template I am using:{lpurl}?utm_campaign={campaignid}&adgroupid={adgroupid}&utm_content={creative}&utm_term={keyword}
What might be the issue?
Hard to diagnose without knowing your method of implementation Ardavan - for example, are you using the Amplitude template in GTM? Other?
dangrainger The info I have from our dev team, Browser SDK and instrumenting includeUtm
includeUtm
I’d suggest using the newer Browser SDK 2.0, it has Default Tracking Options in the initialisation config…one of these is Attribution, turning that on will take care of grabbing UTMs, GCLIDs, FBCLIDs and other campaign parameters.
Full detail can be found here: https://www.docs.developers.amplitude.com/data/sdks/browser-2/#tracking-default-events
dangrainger Do you know why the code rejects the
includeUtm: true,
We are using Browser SDK 2.3.0
Hi, I set integration between Amplitude and Appsflyer(V1) - I see that integration is active but when I'm trying to check this integration in Amplitude section “Connect AppsFlyer” on the second step I see “Listening..” and nothing happend. Does this second step show any activity only if I begin sending events from…
I want to be able to identify and track the users that are hitting a specific page (feature) that is limited by our product tiering in our multi-tenant SaaS app. Our customer businesses have their own segmented dashboard based on the subdomain of the app url (somebusiness.ourapp.com), and I have figured out how to capture…
Hi there, I'm trying to integrate the surveys for react native feature to our app. I've followed the guide and I verify the plugin is "booted" correctly (right user id and device id) but when opening a link, while the linking handlers are correctly triggered, the call to handleURL is returning false - I've verified the url…
