I made events on my plan inactie and published the changes, however the MAU chart is not reflecting the update. Is there some SLA or delay that I should be aware of?
Hi Nikesh - I don’t usually see delays with this. Couple of ideas:
  •  I suggest you try to validate by grouping “Any Active Event” in your MAU chart by “Event Name” to check if you see the events you made inactive.
  • Double check the chart and your plan are for the same project
