Could you pls advise if there are a way to export the tracking plan (schema of events and events properties) to JSON format? I know that we can manually do that by downloading the CSV files, but is there a way to download the JSON format (may be through Ampli CLI?)
Thank you!
Best answer by Yuanyuan Zhang
