I have apps that are built in Ionic with Capacitor and I’ve been using the JavaScript SDK for some time now, which worked great. I noticed the JavaScript SDK is now a legacy SDK and will be deprecated in the future, and there is no direct alternative for Ionic/Capacitor yet.
Does anyone have any experience as to which SDK I should migrate to? The ones that come to mind are the Browser and the Node.js SDKs, but I’m not sure which one I should go for.
Thank you
Hey @lorin
AFAIK, if this is a front end app, then Browser SDK might be more suitable.
I think the Node.js one is more suited for server side implementation since the doc mentions that “it uses the HTTP V2 API” . But I’m not 100% sure.
Maybe a platform specialist can confirm this one.
Hi @Saish Redkar, thank you for the reply. Yes, the browser one seemed more suitable to me too, although they both seem really similar to me at a quick glance. I will probably end up trying the browser SDK as soon as I have time, and hope that it will work fine until a proper Ionic/Capacitor SDK will be developed (if at all).
Hey there,
Yes, indeed, the proper SDK would be the best but for now I would recommend JS/Node.
It’s definitely not 100% ideal solution but the best you could do atm!
Zhenia
