Hello!
We are using a Trial Enterprise Plan, currently using US Data Centres. We are contemplating the option to use EU Data Centres instead - but wanted to know what features are currently supported? For example - are Amplitude Analytics, Experiment and Data all supported? And what would be missing if we were to switch?
Many thanks for your help!
All the best,
Helen
Hi @helen ,
This is Nehita from Amplitude Support, thanks for writing in to the Community!
For the moment, Amplitude Analytics is supported for the EU data center, however Experiment, Data and Recommend currently aren’t available. These products are however currently in our roadmap and we do plan for them to be available for the EU data center in the near future.
I hope this helps, but please let me know if you have any questions!
Nehita
Hi @Nehita I.
Thank you for your reply, really good to know! Do you know if the Govern Add and the ability to import from S3 (https://www.docs.developers.amplitude.com/data/sources/amazon-s3/)  is available in the EU data centre? Thanks!
All the best,
Helen
Hi @helen,
Yes both the Govern Add-on and the ability to import from S3 are available in the EU data center.
Please let me know if you have any other questions!
Nehita
