Hi Amplitude Team,
We’re currently using the Amplitude Scholarship Plan, but we’ve been notified that it will soon expire.
We have a quick question regarding the Starter Plan:
We noticed that the Starter Plan allows for up to 2 projects, but we are currently using 4.
In this case, what happens to the additional 2 projects?
Are they deleted or simply blocked/archived?
Also, if we decide to upgrade to a higher plan later on, will it be possible to restore or access those projects again?
Thanks in advance for your support!
Best regards,
Be the first to reply!
