Mixpanel Destination for iOS
  • 8 November 2022
  • 114 views
Hi we’ve moved over a while back from Iteratively and are just now making sure that all of the connections are set for our iOS app’s Ampli itegration. We want to be able to use the tracking plans and log events with Amplitude and have them flow into our mixpanel instance.
I see that we have a destination set to mixpanel here:
I also see that we have events flowing into amplitude here:
We however don’t see any of these events in our mixpanel instance. Please give guidance on what we should be checking. I also couldn’t find documentation on this so if there is any, a link would be awesome!
Best answer by Jacenda Davis 11 November 2022, 00:46
Userlevel 3
Badge +5
Hello @AskTiaLeo! Thanks for your post and happy to help.
I see that you were sending data to Mixpanel via a now depricated Iteratively integration. Iteratively has since been acquired by Amplitude and is no longer a supported integration/destination.
In this case, you can export the data from Amplitude using the Export API .
I hope this helps!
-Jacenda
Hey @Jacenda Davis,
Thanks for the response! I’ll check out the Export API but I’m really interested in seeing if we can get live events streaming into our mixpanel instance.
I don’t see Mixpanel as a destination --
  1. Is a mixpanel destination something on the roadmap?
  2. There’s a custom webhook streaming destination in closed beta, is that a viable solution for us to look into?
