Java dry run
  • 10 March 2023
  • 195 views
Hi!
I saw that for some SKD is possible to have a dry run.
I run my application in different environments and I don’t want to send events to amplitude from all those environments or from a local run or from integrations test.
How can I achieve that in java?
Thanks for reaching out here @Tommaso Foglia. It is recommended that you have a separate test project for every production project. Here’s more information on how to create and manage organizations and projects. Please let us know if you need additional support.
Hi!
Thanks for the answer. I don’t think a testing environment is what I am looking for.
I might have build running in isolation, where sending data to amplitude won’t be an option.
If does not exists I’ll have to create my own wrapper which won’t do anything.
Go it @Tommaso Foglia. Please keep us posted if you need additional help!
