Has anyone used Amplitude to instrument a component library to measure developer's use of the library and components? We’re planning to instrument our Storybook and in theory it seems like it would be great, I’m just curious if anyone has uncovered any traps/pitfalls with this before.
Thanks for posting here
- Respecting user privacy and being transparent about what data you’re collecting
- Ensuring data quality and filtering out any events that don’t represent real user behavior
- Selecting the right metrics that provide actionable insights
- Not over-instrumenting with irrelevant events or properties; keep your implementation simple
I hope this helps!
Thanks,
Thank you!
Thanks for the feedback
