How can I create an event property that is automatically computed, rather than manually specified? The “channels” is an example of this - you can specify rules that determine what it is set to. How can I make custom versions of this?
My specific use case is with “device family” - it’s too granular. I want to have a report that can simply group by Desktop v.s. Mobile v.s. Tablet, effectively bucketing “device family” values into these groups. How can I do this? I feel like it should be easy but I can’t work out how.
Is there another solution to this that isn’t via custom computed properties?
Best answer by dangrainger
