Hi all,
We are setting up amplitude to see data from our website and app stores - I have added the API keys, but it has been saying “In Progress” for sometime now - wondering how long does it take for an API to save for app stores (google play and iTunes)?
Thank you for your help!
Thanks for reaching out here @jhanvi Were you able to make progress here? There are some considerations to keep in mind and limits documented here. Please keep us posted if you need more support!
Hi @jhanvi Thanks for following up in a DM. I’m going to send this to our support team as well for additional review.
Hello @jhanvi hope you are well!
What SDK are you using to integrate Amplitude? Also, does the app stores show any errors that Amplitude is the issue that you can provide, please?
Hi @jhanvi I hope all is well. Circling back here to make sure you have everything you need. Were you able to make progress?
