How can we measure WAU and MAU separetely?
  • 3 March 2022
  • 391 views
Hello guys,
I am simply trying to measure WAU along a month. Users that have logged in at least one time every week during the period of February for example. I have the proper event set up on the product. Is there any way for that?
It leads to the same question for MAU as well.
Best answer by Saish Redkar 3 March 2022, 17:14
Hey @LucasBSC
A simple WAU chart for Feb will look like this. This is for any event you have marked as active and for all users. Each week’s datapoint will be unique users who have performed any active event at least one time during that week. You can change the event to your logged in event if that’s what you want to measure your WAUs by.
You can create the MAU chart in a similar way by changing the time interval to Monthly and selecting the month range .
Let me know if I have understood your use case correctly.
Ah, it is really simple and helped me think this through. Our use case is a bit different but this is enough for me. Thanks
