Could you tell me about the conversion window and date range in the funnel chart?
Does the date range apply to STEP1 or the entire funnel?
For example, if I set up the following:
  • Date range: January 1 - January 31
  • Conversion window: 60 days
Is a user who generated STEP1 on January 1 and reached the final step on February 2 considered to have converted?
Thank you.
Hi @Mion Nara!
According to your conversion window, the conversion can happen anytime during the 60 days following each day within your date range:
  • A user who generated STEP1 on January the 1st and reaches the final step before the 1st of March will be considered to have converted.
  • This will apply to everyone who generated STEP1 from the January 1st to January 31.
  •  The last convertions will occur from people who generated STEP1 on the January 31 and completed the final step on the March 31.
(Correct me if I’m mistaken 😄)
Hi @Matrak,
Thank you very much for your reply! I appreciate it.
I could not find any mention of this in the user guide, so I was not sure.
Thank you for your detailed explanation!
