Hi !
I have follow the steps here to export data to bigquery. The issue is i can only have data from the day i have set up the connection but not before.
How can i retrieve the data from 3 or 4 month ago ?
Thanks
Hi !
Thanks
Hi
After you create the destination, you should then be able to see a Backfill tab that will allow you to configure the date range in which you would like to backfill the data. Hope this helps!
