Chart metric not showing up
  • November 3, 2021
  • 417 views
Forum|alt.badge.img
I've been seeing this for a few days, on the dashboard chart metrics (conversion rates) won't load:
Is there something I need to adjust to fix this?
FYI - when I click into the chart I can see the conversion rate all right, just not on the dashboard.
Best answer by Yuanyuan Zhang
Hi @artcities
This is Yuanyuan from the Amplitude Support team - thank you for bringing this to our attention. We are in contact with the engineering team for investigation. I will let you know once I have update. Apologies for the inconvenience.
Kind regards,
Saish Redkar
Expert
Forum|alt.badge.img+10
Hey @artcities
You should be able to toggle the conversion rate view via KPI → Conversion Rate.
If not, then this could be a potential dashboard UI bug.
Let me know if I have understood your use case correctly. Hope this helps!
Forum|alt.badge.img
  • Author
  • New Member
  • November 4, 2021
Saish Redkar wrote:
Hey @artcities
Yep tried that it still doesn't work.
Looks like a bug?
It's been there for more than a week now.
Yuanyuan Zhang
Team Member
Forum|alt.badge.img+5
  • Team Member
  • 181 replies
  • Answer
  • November 4, 2021
Hi @artcities
Kind regards,
Yuanyuan Zhang
Team Member
Hi @artcities
Our Engineering team has resolved the issue. Sorry for the inconvenience and please let us know if you run into it again!
