Where I can find the API secret to connect session replays? I am currently on starter plan and wnat to try this feature. Thanks in advance for your help
Hey Denis, thanks for your message! The API keys can be found by going into Organization Settings (click the gear in the top right) > Projects > and then click into the associated project you’re using. Once you’re there you should be on the general tab and it’s listed there.
If you don’t see it, it’s likely due to your user role. You need to have admin or manager access in order to view these.
If you’re trying to connect Session Replays with an API secret, heads up—Amplitude has moved away from API secrets for security reasons. Now, you’ll need to use personal or project-level API keys instead. You can find them under Settings > Projects in Amplitude. Also, double-check that your account has the right permissions for session replays.
