I’m trying to get the number of users who performed all three specific events so I can work with that number in the formula bar… I tried UNIQUES(A,B,C) and UNIQUES(A+B+C)
Is there a way to do this?
Hi Revel Formula approach won’t help much here since it is more suitable for getting the total of uniques who performed those 3 events individually rather than uniques users who performed all 3 events.
e.g this demo chart - https://analytics.amplitude.com/demo/chart/new/srqy32n
Per the formula in the chart, you will get the daily arithmetic sum of uniques performing the 3 events separately.
If you want to get unique user count who have performed all three specific events over a given time frame, then a segment or cohort approach will be helpful.
eg. this chart - https://analytics.amplitude.com/demo/chart/new/9mdth0m. In this chart, you get your unique count of users who did all those 3 events during the last 30 days.
Make sure you are using the same time frame for each of the performed clauses as results may differ accordingly.
