Second Y-Axis on Line Chart
  • 17 August 2022
  • 636 views
I’d like to have metrics with different scales on the same chart.  For example, I’d like to see the raw counts for subscriptions and also a conversion rate.
I can do that with formulas just fine, but it’d be helpful if the percentage scale could be on the right while the raw counts were on the left.
Is there a way to do this?  If not, how would one request a feature like this?
Best answer by Saish Redkar 17 August 2022, 18:17
Hey @tncbbthositg
That’d be a nice feature to have. You can submit the request in the Ideas section.
Ideally, if we are using 2 custom formulas then having a second customized Y axis could be super useful to set the context.
Thanks for plugging the product ideas forum @Saish Redkar! You’re the best! 😀
