Max parameter data size for an event
  • 5 November 2021
  • 745 views
Hi guys, we’d like to know what is the maximum character length is for the parameters we attach to an event?
We’d like to use this info to limit the amount of chars on the frontend to a sensible length. Couldn’t find this info in the documentation nor in public headers, so it might be prudent to add it there as well.
Best answer by Saish Redkar 5 November 2021, 15:37
Hey @markohlebar
The current character limit is 1024 characters for all string values.
You can read more about the various limits in here. Hope this helps!
That’s perfect @Saish Redkar. Thank you very much!
Userlevel 3
Badge +2
Hi @Saish Redkar
We’re using the Kotlin Android SDK and for some reason my event property values for strings are getting truncated to 95 characters. The Android devs say they’re not truncating. Any ideas?
Thanks,
Anthony
Userlevel 3
Badge +2
Nevermind! After consulting the new Support Chatbot AI, the devs were able to look at this and figure out where they were truncating it :)
