We used the same Amplitude project and event names for lots of international markets so that it’s easy to compare one market to another in the same chart. Now that some of the markets are closed, is it possible to make a global change to our project so that all old events from a closed market no longer appear?
Today, we usually add the same User Property filter to all charts in order to exclude that market:
User Property: app_name ≠ {tim_fun}
...and when we forget to add it, it looks like our DAUs dropped.
Thanks for your ideas.
Hey @Anthony which plan is your org on?
Drop filters enable an org to remove all event data that meet specific conditions, such as when the app_name = {tim_fun}
Alternatively, if your org doesn’t have access to this feature, there is a save segment feature that enables an org to save user segments and set them as default to all new charts moving forward. This resolves the pain point of having to remember to apply the filter to all new charts, and by default is applied to new charts.
Let us know if you have any follow-up questions on this
Thanks. That sounds like exactly what I was trying to do!
I saved my drop filter.
For some reason, I’m still seeing them in the charts though.
https://app.amplitude.com/analytics/play2pay/chart/new/el6cggwn?source=copy+url
Hey @Anthony thank you for sharing the screenshots and link! Did you set up the drop filter on the user property app_name, or on an event property?
Since I noticed your chart is grouping on the user property, you may need to update the drop filter to the correct prop.
Let me know if that helps update the drop filter to work as expected
Wow. Good eye. Yes, that was it, we needed to use user property instead of event property. Thanks!
