Files saved in gz format and not csv on the S3
  • 22 March 2022
  • 704 views
Hi ,
I am quite new in Amplitude and recently successfully implemented S3 integration by the book
as listed below .
https://help.amplitude.com/hc/en-us/articles/360044561111-Integrate-Amplitude-with-Amazon-S3
Everything works fine exclude the format of the file is .json.gz instead of CSV as expected .
Is there a way to change a format to CSV by default  ?
Best answer by Saish Redkar 22 March 2022, 16:20
Hey @pasha.shwartz
Afaik, that’s the default option of any event data export from Amplitude i.e. zipped archive of JSON files.
I don’t see any explicit mention of csv output in that documentation. Maybe this is something the Support Team can enable from the backend if possible.
Badge +5
Hi @pasha.shwartz
@Saish Redkar is absolutely correct that any event data export from Amplitude will a zipped JSON file. Currently we do not support S3 export as CSV files. But I strongly encourage you to submit your feedback and use case in the tab Product Ideas
Hope this clarifies!
