I know this is documented quite well here: https://www.docs.developers.amplitude.com/experiment/general/evaluation/implementation/#activation
But this experiment is very important, so I just want to make sure I have this right.
We have 3 flags that we want to ensure get to the same users. If we use the same Bucketing Salt for each of the flags, then if we keep the segments and rollout numbers the same, then the same users should receive all 3 flags. Is this correct? Are there any pitfalls that we should be aware of when doing something like this?
Thanks in advance.
Best answer by Thao Nguyen
