I am seeing a difference between what I filter and the data that is shown.
Why could this happen?
Hi trosen,
Thanks for your reply and apologies for the late response! You can do a user look-up and view their individual event stream and see what the value was at the time “Deal Won” was performed.
The user properties displayed with each event in a user's individual event stream capture the value of the user property at the time of the event. The exported file will show the most recent user property values. I think this user may have fired an event after Deal Won that had a value with “cpc” and that’s why you see it.
https://help.amplitude.com/hc/en-us/articles/115002380567-User-properties-and-event-properties#h_856d23e3-10ea-4398-a50d-4982a42d1f3f
Let me know if you have questions or concerns!
Best, Loc
Thank you for the screenshots of this issue. Is “initial_utm_medium” an event property or a user property? Also, can this property value change when another event is sent to Amplitude?
The reason I ask is that when you download a .CSV of users, the file will contain each user’s most-recently sent user property values. I think this might be the cause, but let me know those first two questions and I can take a closer look! Thanks.
Loc
Hi Loc Tran!
Is there any way to see this? Could I confirm this somehow? (that it doesn´t change)
Regards,
Tal
Hi Loc Tran,
Don’t worry. But that was exactly the case, we figured it out a couple of days ago.
