Hi Mithra B
That’s a pretty open ended question given the depth and breadth of impact you can create using product analytics and Amplitude.
I would suggest the going over the following resources -
You can also use the Solutions section at the bottom of the blog page to get a high level use case overview
There are definitely more resources out there, but these will help you get started. Hope this helps.
Yeah. Thank you Saish Redkar
