I currently have multiple projects depending what version of my iOS app is being launced. An example would be a dev project and a production project.What do I need to do so that the Ampli SDK automatically knows which project should be used?
Hi irmalexandra ,
Denis here again! You can create a new project in Data itself and it will create two projects for you, one production and one developments. You cannot add more environments than that at this time. Ampli SDK will know which Data project to use when you login with ampli login, you should get options to choose which Data project when you have two or more.
Kind Regards,Denis
Hi Denis,
This sounds like the answer I’m looking for! I’m unclear what you mean by “create a new project in data itself”. In the Amplitude dashboard if I navigate to Analytics then in the left bar I can go to: settings → Projects → Create ProjectIf I instead switch to “Data Beta”, the left bar Settings does not contain Projects (it contains: General, Environments, etc).I was wondering if you could clarify the steps to create a project in Data itself?
Owen
Hi OwenC ,
You would need to create a project inside Data in the top left hand corner when you enter Data. You can click on the branch below the Data Title and there you will have an option to create a new project.
Hi Denis Holmes,
Thanks for the fast reply! I had manager permissions and the Create new Project button was not visible but with admin privileges it is.
Thanks,
What was the name of the project which you cannot see in Data? I can take a look! (If you can let me know your Org ID too, I need that, you can PM me it).
We're losing user journey tracking when anonymous users switch devices during our sign-up flow. Our typical flow: anonymous user visits homepage on desktop → clicks Sign Up → redirects to Auth0 for registration → user verifies email on mobile (creating a new anonymous user ID) → returns to desktop to complete sign-up and…
Clicking ‘Mark all 7 as read’ is not doing anything to clear my alerts MacBook Air 14-inch M4 macOS: 15.5 Browser: Chrome Version 136.0.7103.114
Reality Beyond Dreams is a team of impact producers. At the heart of every film we produce, and every campaign that we design, are the core principles of Social Impact Entertainment. We are dedicated to creating cinematic projects that promote https://realitybeyonddreams.com/
Hi everyone, I’m working on adding Amplitude to a single mobile application serving multiple countries. Inside the app, users are shown a country selector panel (e.g., Egypt, Turkey, UAE, etc.), which determines the localized experience they will receive — each country has its own UX flow and logic. The client wants…
I have installed Amplitude via Google Tag Manager and looks like the user ID is not being set. I have installed 2 tag from GTM. * Tag type as init * Tag type as setUserId Still say Anonymous user
