Hi, is there any way to add more than 2 return events to be shown in the retention?
Or any other recommended chart, in this case, I have 10 types of products separated by event properties and I want to see each retention rate.Thanks
Hi Chidada
The retention chart supports only two return events at this time.
I’m not sure if I understood your use case fully , but if you are trying to see retention across user properties then you can use the group by clause.
If you are looking at event properties, then you might have to create individual retention charts filtered on each of the properties on the return events.
Hello. I'm getting stuck trying to calculate a metric for my team. I'm trying to measure the median Session Duration for users who are looking at a pop-up modal. Here's my formula. Can someone help me figure out how to get around this error?
