Currently, inspecting a datapoint (via Microscope) generated in an event seg chart using a custom formula metric isn’t supported.
It would be great to have the option of playing back video (and having the video preview) in a 9:16 (vertical) orientation so that an end user of a video in a guide didn't have to full-screen the video in order to have it play in the correct orientation. It would also be great to have support for Wistia as more and more…
Hi, I’d like to request a feature: it would be really helpful to have the ability to shuffle or reorder properties within an event, especially when grouping. Right now, adjusting the order of grouped outputs is quite cumbersome.
When changing a property value, because we often have complex and long values, we paste the exact value in the search bar. However the matching value will appear at the very top but all other values will remain, which makes the search complex and we lose a few seconds each time Here is a loom to show my point Thanks !!
I am creating a template for our experiments dashboards I would like it to be as self serve as possible, making stakeholders changing the fewest things as possible. They have the ability to change the properties values but NOT the exposure key, which is a problem as they have to go in every chart and change the key, which…
