Hi everyone,
I am trying to organize my Dashboard better. Created some subfolders that was not needed, but the action menu does not have a delete button (just Rename and Copy Link).
  • How to delete subfolders in Amplitude?
  • Is this due to my limited access?
Hi ​@Faeez M. Noor
AFAIK, you can only archive them. You can find that option once you are in the parent folder and after you select the subfolder. It’s not directly available in the side nav bar.
