Hi all, does anyone know how to remove “items” in Platform? Right now it is quite cluttered. We only would like to have e.g. (none), iOS, Android.
Could not find that option in the UI.
Could we try to delete the users that “had” those “platforms” and would that remove the items?
Hi ​@Nils
You can hide the property values using transformations
https://amplitude.com/docs/data/transformations#hide-property-values
Hey Nils,
Ben from Technical Support Team.
As Platform is Amplitude Default property I am not sure this is possible to transform this property.
I am reaching out internally to see if there is any possibility to clean it.
Best regards,
Ben
Ah, good catch ​@BENOIT LIEVIN
I missed that fact. If it’s the default Amplitude Platform property, then Amplitude wouldn’t allow any direct transformations on that.
No problem it was still a very good idea!
I am still waiting the answer from the engineer team regarding your case Nils.
Hey Nils, I believe your issue has been fixed can you take a look ?
Best regards,
Ben
@BENOIT LIEVIN
Looks good! How was this done and who should I thank 🙂 ?
The engineer team cleared it as a one time demand 🙂
