Hello
I'm Roh Jae-Gwon.
There is a SPACE that I created by mistake, and I would like to ask if it can be deleted.
The SPACE you want to delete is the link below.
https://app.amplitude.com/analytics/Hanatour/space/uv6hdy0t/all
Please check even if you are busy.
Thank you.
Hi Jae-Gwon,
Thank you for reaching out!
Unfortunately, Amplitude does not currently support the ability to hard delete a space. That said, you can archive spaces to remove them from the list of active spaces in your organization.
To archive a space, follow these steps:
1. Navigate to the space you want to archive.
2. Go to Settings and members on the bottom left of your screen.
3.Click on the Archive button
Please let me know if you have any other questions.
Best regards,
Thao
Thank you for answer.
But if I click the Archive button
"You have not archived any items yes" comes up
In this situation, how can you tell me the steps in detail how I can remove it from the active space list in the organization?
Hi Jae-Gwon,
Apologies for the confusion! Please refer to the screenshot below for the Archive option. I'll update the screenshot in my previous response to prevent any confusion for other Community members.
Best regards,
Thao
