Deleting a Space
  • 21 May 2023
  • 286 views
Is there a way to delete a Space permanently, I can archive a space but it still shows up in “spaces”.
Thanks for your help!
Best answer by Esther Trapadoux 22 May 2023, 15:56
@Roee Fink hi! Ah yes, deleting spaces. At the moment, it's not possible to delete spaces as we don't support hard deletes on spaces. The only option is the one you’ve found - archive it. You’re definitely not the first to ask and probably not the last, I’ll let the Product team know! 😅
Hello!
Could you please tell me if there is a chance still to delete the spaces?
We created a lot during our POC for amplitude and now its a mess - we really need to clean it up.
Any help will be highly appreciated 😊
Ah too bad spaces can’t be deleted!
Especially because, when creating a new space, it gave me an error, and I tried again - so now I have 2 spaces (at the moment both are empty) created accidentally for the same purpose. I really want to get rid of one, even if someone at Amplitude support can do it behind the scenes, that’s fine.
The space create option seems to have a bug, and makes users create duplicate spaces.
