I have dev and prod Amplitude projects for both a web app and a mobile app. (4 projects)
I see theres a way to import and export the schema between projects.
The mobile app will use custom events to refine autocapture element interactions by their target accessibility identifer for easier use.   Web will use visual labeling.
Is there a way to copy over custom events and labeled event definitions from one project (dev) to another (prod)?
Hello Mike,
Thanks for writing to Amplitude Support. I hope you're doing well. I see that you're currently working from an organization that still utilizes the
Environments workflow. You can access this feature at this link: https://app.amplitude.com/data/crickethealth/Demo%20-%20CTH%20Data/settings/environment. With this workflow, you can add projects to the same Environment and the tracking plans will be automatically synchronized. This is the closest feature we have to a 'copy to' functionality within the Environments workflow.
However, for newer organizations, we have introduced a 'Copy To' feature: https://amplitude.com/docs/data/work-with-branches#copy-branch-changes-to-testing-environments. This feature is currently not available for organizations that were created earlier, like yours. But don't worry, our product team is working on releasing the 'Copy To' functionality to all organizations soon.
I hope this information is helpful. If you have any more questions or need further clarification, feel free to ask.
Jacenda
