Writing an absolute value in a chart
  • 4 October 2023
  • 165 views
I’m trying to create bar chart in the segmentation tool. I’m using the formulas. I would like one of the bars in my chart to have a fixed value (“1.72”). I tried to write it in different ways in the formula form, but I always get an error from Amplitude. Is there a workaround for this? Thanks
Have you tried dropping in a formula that forces a fixed 1.72 value? For example, UNIQUES(A)/UNIQUES(A)*1.72.
Hope this helps @Valentin Lecomte!
Thank you @dangrainger , it works!
