As mentioned in the title, user path of funnel analysis doesn't appear. Attached is the pics of issue
Hi John Kim and Michal Grzelak thank you both for confirming this issue is not related to the funnel order type.
I was able to replicate this issue in a starter org, so I have logged a bug for our engineers to investigate further.
In the meantime to support your analyses, you could leverage the following charts to gather more insights on which events users are performing between event A and B
Hi John Kim I’ve seen this behavior before when the funnel analysis order is set to exact order.
Could you modify your funnel order selection to this or any order and let us know if that renders user paths?
Thank you
Same problem here, no matter what order is set. is this a bug?
JennRu my funnel analysis order is set to this order, not exact order. As Michal Grzelak said, the order set doesn’t matter.
JennRu Hi, JennRu, this is John kim. Could you inform me of how this issue is proceeded?
Hi John Kim the engineers have resolved the jira ticket as of May 26. I can confirm this is working in a few orgs that I have spot checked.
Please let me know if you are able to complete your analysis now, thanks!
