Revenue LTV per network/campaign analysis
  • 15 December 2021
  • 131 views
Hi guys, nice to meet you.
I was wondering if there is a way to filter users by UA networks in the Revenue LTV chart section please ? Also, if possible, can we get the granularity per UA campaign in each network?
Currently, I can’t see any “network” tab in the “Amplitude User Properties” : is there a way to connect Amplitude to our MMP to obtain network sources for each user ?
Thanks in advance for your help !
Best answer by Saish Redkar 15 December 2021, 19:30
Hey @Thomas C
You can segment/filter the Revenue LTV chart by your campaign as long as you have the correct properties instrumented to account for the attribution. Here’s a demo chart.
Amplitude doesn’t capture these by default as listed under the “Amplitude User Properties”
Here are some few posts/links which can help you get started in setting up your attribution tools data:
- https://developers.amplitude.com/docs/attribution-api
