Currently I have made 3 (WAU, DAU, MAU) charts for each user but this is a long winded approach.
Daily Analysis → click here
Weekly Analysis → click here
Monthly Analysis → click here
Please share videos for quick understanding.
garima
I’m not able to comprehend the “we have two users who are DAU” part. Any user who is active on a given day will roll up to being active during that given week and ultimately active for that month.
From what I understood, you will have 3 charts with a daily/weekly/monthly granularity against the same time frame - e.g. Last 3 months ↔ Last 12 weeks ↔ Last 90 days.
Each of these can be grouped by username and a line chart.
So if you end up using the bar chart view for each of those charts, you will only see the usernames who were active over the aggregate period.
Hey garima
Can you elaborate on “this is a long winded approach”?
Since I’m not part of the Amplitude Team, I won’t be able to access your org chart links.
The most common approach for DAU/WAU/MAU charts in Amplitude would be to define your Active Event and the right segment for your active users ( if applicable ) and chart them as uniques separately in a daily/weekly/monthly level.
A sample DAU chart would look like this - https://analytics.amplitude.com/demo/chart/new/mz4g9zr
Hi Saish,
Thanks for your chart.
Currently we have a small group of users only. So I want to make a chart at Amplitude where I can see username in DAU/ WAU/MAU.
for ex. Chart 1 → DAU → we have two users who are DAU so this chart will show only those two user’s { A and user B }
Chart 2 → WAU → we have 3 users who are WAU so this chart will show us those 3 users. {user c, D and E}
Chart 3→ MAU → we have 1 only only so this will show us that one user only. {User F}.
I am happy to connect with you on teams or Goggle chat if that works for you.
Cheers,
Garima
Saish Redkar
I want to classify all my users into 3 categories and just on seeing the chart of each category I want to know which user of mine is present in it.
Hi Garima,
Can you clarify the use-case and what you are looking to achieve? Do you want to see all of these users on a single chart view?
