Hubspot Integration: Hubspot as Source
  • 19 June 2023
  • 150 views
Has anyone been able to make the Hubspot as a source work?
I keep trying and The OAuth screen pops up with a acceptance box, but redirects so fast, you are not able to read it or accept it. Then you simply get a 403 error.
Is there a workaround that someone has to get this working?
Best answer by Brad Ranks 27 June 2023, 17:28
Hi @Brad Ranks
As per the below post, dated 4 months ago, the Hubspot integration wasn’t available on the Starter Plan and might have needed to be specially enabled for your account.
Not sure if this is still the case, but your issue might be related to this.
Thanks @Saish Redkar , it seems that is correct.
I spoke with the teams and it is now enabled on our account.
One thing that I feel is worth mentioning is that even after you enable and connect them, there is still a prerequisite step of setting up ‘email’ as a filed in Amplitude, in order to connect them together and map the fields that will be passed.
Thanks and I hope this helps a future searcher.
@Brad Ranks super helpful, thanks for pointing this out. 🙏
