How to display multiple shared dashboards into one dashboard?
  • 8 November 2021
  • 116 views
Userlevel 1
Badge +1
Hello, I am looking for a way to organize all of the externally shared dashboards. Ideally create some sort of central tracker in amplitude that contains the links to each of the dashboards / passwords. Any ideas or tips would be much appreciated.
Best answer by Saish Redkar 9 November 2021, 02:34
Hey @aalqaroot
Ideally, this can be organized in a Notebook , wherein you can format links and text as per your preference. If you are just looking to organize a bunch of dashboards, then you can try organizing them in the desired Team Space.
Userlevel 1
Badge +1
Hey @Saish Redkar
Thank you so much for the suggestions. I am playing around with it on a notebook and so far its looking good.
-Abdul
