Exclude last 4 weeks of data from Segmentation Chart
  • 12 July 2022
  • 109 views
I have a chart that looks below where there is a downward trend as shown.
This is a custom formula that I have calculated. I would like to exclude the last 4 weeks of data. Is it possible to add a statement to the formula so that the fisual goes from Apr 18 to June 12?
I want to see all the data that is at least 4 weeks old!
Best answer by Saish Redkar 12 July 2022, 18:13
Hey @sebhatyidelwo
You can use the offset clause to do this
Else, if you want to visualize data only between 2 dates then you can use the Between clause in the date picker.
Let me know if I have understood your use case correctly. Hope this helps.
Amazing sir, you are a genius
