Event Segmentation - Group by (Group numerical values)
  • 22 September 2021
  • 234 views
Hello,
I’m trying to do an analysis on one event. For example, Add Item to Card and Group By ‘Age’.
The issue I’m having is that I have a lot of Age values from 18 to 60 so something around 42 unique values. Which makes the analysis very hard.
Is there a way to group the values by buckets for example 18-25 25-35 35-45 … ? So the analysis would be easier ?
Thanks a lot,
Matthias
Best answer by Saish Redkar 22 September 2021, 18:32
Hey @matthiasr
You can leverage the Properties metric and measure the Age property using the Distribution of Property Value option with custom interval sizes. Something like this .
Thanks a lot !
Badge +3
If you need more control over the different bin sizes, this kind of approach is also possible, although a bit wieldy.
